View previous topic :: View next topic |
Author |
Message |
Joined: 13 Jul 2004 Posts: 1200 Location: Issaquah, WA USA
Posted: Mon Jun 13, 2005 2:53 pm Post subject: Bdelloid Rotifer head+ rotifer juggling haematococcus |
The motion of the cilia on certain rotifers (especially the bdelloid and limnias) have fascinated me since I observed it for the first time. It was a major impetus to setting up an electronic flash almost as soon as I set up my microscope. I've taken far too many pictures of this subject already, but can't resist trying to get one just a little better than before.
The top image is one of the occasions where many elements happened to work just right. I was using a "high/dry" 63X objective with a correction collar. It's always tough to "set" this correction just right with a subject that is in constant motion, and constantly moving closer and farther from the coverslip. The body position of the subject is critical since the slightest "wrong" angle to the head can throw most of the picture out of focus due to the shallow DOF. Not to mention trying to track, frame and focus a moving subject. So you just keep taking pictures as fast as you can and hope that you get one where it all works out. The lighting for this top image was oblique brightfield. It worked well, giving a pretty "life-like" 3D effect.
The lower image was taken using "regular" brightfield. These rotifers can create quite a current when feeding. On this slide there were a good number of haematococcus (thanks Wim... didn't know what they were until your post!) floating around, and they were continually drawn to the rotifer. Sort of a nuisance for the rotifer, since this is not "food" for her, and the haematococcus just get in the way of feeding. But it made a sort of comical shot, as if it were playing with a beach ball. |
Back to top |
Wim van Egmond
Joined: 08 Apr 2005 Posts: 440 Location: Rotterdam, the Netherlands
Posted: Tue Jun 14, 2005 2:55 am Post subject: |
Ouch! I have never seen such resolution! It is magnificent Charlie! For many subjects there is nothing better than brightfield. But it is hard to get good contrast and resolution as well. These images are nothing less than photomicrographic perfection!
Wim |
Back to top |
Posted: Tue Jun 14, 2005 5:15 pm Post subject: |
Thanks Wim. The way I am set up now allows me to set my flash at about -6 to -7 for these brightfield shots. I think that certainly helps make shots like this look "sharp" since the flash duration is probably around 1/30000 second! Still, all those other factors must fall into place as well... |
Back to top |
Ken Ramos Site Admin
Joined: 04 May 2004 Posts: 4809 Location: Western North Carolina
Posted: Tue Jun 14, 2005 7:06 pm Post subject: |
Beautiful Charlie, especially the lower image  _________________ Site Admin.
Reposts of my images within the galleries are welcome, as are constructive critical critiques. |
Back to top |
