Cranefly haltere
Post your images made through a compound microscope or made with a stereo/dissecting microscope in this gallery. Images may be of any subject natural or unnatural, living or non-living.
Cranefly haltere
Post by Charles Krebs »
well... Wim asked, so here they are. :wink:
The halteres of flies are the small club shaped structures that are located where you might find rear wings on some other insects. (Flies only have one set of wings for flight.) They are quite prominent on this large cranefly. They are usually refered to as the "vestigial" or "rudimentary" rear wings. They serve as "gyroscopes" or balancers during flight. Interestingly, research has shown that (at least on some flies studied) they also receive the flight directing stimuli from the insects vision rather than that stimuli going directly to flight muscles, as might be expected. If this is of any interest you should read this link:
http://www.berkeley.edu/news/media/rele ... 9_98a.html
piotr
Post by piotr »
Thank you for this very interesting post. Beautiful pictures, as usual.
Are these 3D reconstructions, too?
Both of these photographs are absolutely beautiful. After reading the article linked, it explains why these little pests are so hard to swat at times. Their form of internal guidance can be compaired to that of an air launched missile, where "pick-offs" or potentiometers are used to relay guidance information to the control surfaces from the navigational gyros. Cool eh! :D 8)
Piotr... these are both done with image "stacks" and HeliconF. The first one (2.5X objective) could probably have been done OK without it, the second one (10X objective) could not have.
Ken... I thought the link was pretty interesting as well. How would like to have been the guy trying to stick electrodes into specific flight muscles of a live fly? Neat stuff.
Wim van Egmond
Post by Wim van Egmond »
Wonderful!
I have ask Charlie to do the work since the first test film with my new flash set up was all over exposed. It is good that I have so much patience. :D
Wim
Post by Mike »
Hello Charlie,
Wow! You take an ordinary subject and make an extraordinary photo.
Thanks, again.
lacerta
Post by lacerta »
One of the tests we had in zoology was to key insects. To complicate matters, most of them were just dismembered parts. The order Diptera was always a no brainer, because if you had a thorax with a haltere, you knew immediated it was a fly of some sort. Great shot Charles.
GreenLarry
Post by GreenLarry »
Wow, i thought the first pic was cool enough, then i saw the second one-fantastic!
